DOOR POP & CREEKS
Subscribe
Apr 2, 2009 | 12:40 PM
Ok i am about to go pick up my 88 rs and the driver door hinges pop and creek horribly! I was thinking i could just plop some greese in there and be done but will this fix it? or what should i use?
Reply 0
Apr 2, 2009 | 12:42 PM
Re: DOOR POP & CREEKS
Quote: Ok i am about to go pick up my 88 rs and the driver door hinges pop and creek horribly! I was thinking i could just plop some greese in there and be done but will this fix it? or what should i use?
Sounds as if the door hinge and/or pin needs to be replaced.
JamesC
Reply 0
Apr 5, 2009 | 09:04 PM
Also a lot of times the roller on the lower hinge makes a popping sound as you open and close the door if it's worn. If thats the case it's too late for grease but it's never too late to purchase a new roller and pin and make your 3rd gen like new again. And after you install that, go ahead and throw some grease on it ... and everything else that needs a little lube every now and then.
Reply 0
Apr 5, 2009 | 09:50 PM
Quote: Also a lot of times the roller on the lower hinge makes a popping sound as you open and close the door if it's worn. If thats the case it's too late for grease but it's never too late to purchase a new roller and pin and make your 3rd gen like new again. And after you install that, go ahead and throw some grease on it ... and everything else that needs a little lube every now and then.
i would still just try some simple grease
i had a leased continental that started creeking after my cousin left the door open all night one night, i brought some $2 grease from walmart and problem solved
Reply 0
Apr 5, 2009 | 09:53 PM
I think putting grease will you...If not, that's the time you will need to seek some help...
Reply 0
Subscribe
