How do i take the ground effects off my 88 trans am
Old May 6, 2009 | 12:06 PM
chrismann888's Avatar
Car: 1988 t/a white
Engine: crate 355
Transmission: rebuilt orginal
My cars going in for a brand new paint job and im taking the ground effects off myself. For the door ground effects how do i take them off do i have to go into the interior and wheel well. I need as much help as possible i do not know how they come off.
Old May 6, 2009 | 12:10 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: How do i take the ground effects off my 88 trans am
To get the door ground effects off, there is two bolts in the door jamb themselves, and 3 bolts holding the middle of the part to the door behind the door panel. There are three odd shaped holes in the bottom of the door to allow you to fit a socket wrench in there. If you are speaking about the lower side skirts below the doors, then there is 5 phillips head screws in the door jambs, 2 11mm nuts inside the front fender, 1 11mm nut inside the rear quarter panel accessed by taking the lower rear armrest interior panel out, and then approximately 6 or 7 7MM screws underneath. This is if none of the hardware has been replaced before. Anything else i can help you with feel free to ask.
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
