GTA Hoodvents
Old May 7, 2009 | 09:41 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
GTA Hoodvents
So I took off the two front vents and re painted the screens behind them black. I wanted to do the back two by the wind shield and I wanted to know the process of taking them off? Thanks
Old May 8, 2009 | 08:52 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Re: GTA Hoodvents
They snap in. If you go in from the back side with a screw driver gently push the edges of the "snaps" they will come out. I don't remember if you have to remove the hood bolts to access the "snaps". ( I think I did) Memory is not what it used to be.
Old May 8, 2009 | 11:17 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: GTA Hoodvents
I was afraid taking out those hood bolts. Thanks alot man, I will play around with them more tomarrow
Old May 9, 2009 | 07:57 AM
racerx520's Avatar
Re: GTA Hoodvents
when i did mine the rear ones did pretty much snap out, i forget exactly how.
the front ones were the pains in the ***, they have two bolts holding them in, i think its like 13mm, but there isnt enough room to get a socket in there, so what i had to do was try to use a pair of needle nosed pliers and just work it out slowly, it was not much fun lol, there is no real structural need to have the holes this small there, so ifyou wanted to im sure you could just use a dremel on it, i was about to lol. it just looks like poor planning on GM's part when you look at it
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
