another door hinge question
Old May 19, 2009 | 06:02 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ok guys im having major door dropping and scrapping along my ground effects. is it easier to replace the hinges or get the pin kit? i can lift the back of door and it moves around alot when i wiggle up and down. it also "drops" when i open the door, and its hard to close. where can i find these parts? links would be great!
Old May 20, 2009 | 12:22 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: another door hinge question
The lower hinges can have their pins replaced, but the upper cannot. Due to the design, the upper was not meant to be serviceable. The original hinges were supposed to be replaced as a whole unit, not for the faint of heart. However, Lon over at top down solutions has a great fix for these upper hinges.
Old May 20, 2009 | 02:18 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
The upper pins take some grinding to remove, they aren't meant to be serviceable, but with all the kits available now, they are. With your doors in that kind of condition, the lower hinge might need to be modified or replaced.
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
redmaroz
Aug 16, 2015 11:40 PM
