Front ground effect...how to attach to fenders
Old May 26, 2009 | 10:29 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I kno from the factory there was a metal plate with three studs that would slip behind the gfx and bolt onto the fender. The problem is i dont have either of these pieces and would like to attach the gfx on friday when i "think" im getting it back from the body shop. What is the best way to go about this? Has anyone just not attached it there and just bolted it on on the back bottom? Is there another way that people do it?
Old May 26, 2009 | 07:47 PM
p100ki's Avatar
Re: Front ground effect...how to attach to fenders
You can get a similar piece of flat metal from lowes/home depot and make your own. Just cut it down to size lay it over the holes and mark them with a sharpie. Then you can drill them and use normal nuts and bolts. I weld the bolts to the backside of the metal and undercoat them so they don't rust but you don't need to weld them if you don't have access.
Old May 26, 2009 | 09:01 PM
subroc's Avatar
Engine: 355 TPI
Awesome! Thanks for the advice. Ill probably end up doing it that way since i do have one of those pieces to go by (studs are broken off).
Old May 26, 2009 | 10:22 PM
p100ki's Avatar
I've done it on several cars i've worked on, including my own due to rusty studs. It's really simple and the closest you can get to factory. Good luck...
Old May 27, 2009 | 11:36 AM
subroc's Avatar
Engine: 355 TPI
Just finished making my replacement brackets. I was able to find everything i needed at the local hardware store for a hair under 10 bucks! I cut the metal flat stock to size. Measured and drilled my holes and then threaded the bolts into them. I purposly drilled the holes a bit on the small side so i would have to force the bolts into them so they cant move around. They look great and i just test fit them on the fenders so they should be good to go. Thanks again for the advice.
Old May 28, 2009 | 09:26 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Same here!
Old May 28, 2009 | 11:39 PM
p100ki's Avatar
Glad to help, cheapest and best way i have done it.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
kyleb24
Aug 15, 2015 08:24 AM
