What to look for when buying a Trans Am?
Old Jun 30, 2009 | 05:19 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Ok, so my car is dead, or rather dying, so im in the market for a new one. Im really looking for ThirdGens, but i cant seem to find many in my price range. Im going to look at a car on monday, its an 87 5.0 TPI 700R4 with t-tops and a salvage title from water damage sustained in 1989. Probably in a hurricane, i hear there quite common in Florida. Its got about 120K on the clock. Other than the usual spots for rust, and no leaking fluids is there anything else i should look for on these cars? I made a few mistakes assuming alot with my past car and i dont want to make the same mistakes. I know where to check for rust, my current car has tons of rust on it.
Also does anyone have a handy list of the RPO codes and what they represent? I know we have the decoder on here, but i dont plan on bringing my computer with me.
Old Jun 30, 2009 | 05:54 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: What to look for when buying a Trans Am?
RPO list there you go, dunno how accurate or complete it is tho
Old Jul 1, 2009 | 01:52 PM
Firebat's Avatar
Could get the VIN and do a carfax report on it. I would avoid T-tops like the plague unless you really, really want them.
Old Jul 1, 2009 | 02:12 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Check around for loose wiring. A lot of people buy third gens only to notice too late that there's a rats nest right by their feet. People love to try their hand at car alarms, remote starters and audio in these cars, and they often fail.
Check the fitment of the windows to the frame and see if there's obvious leaks (same goes for T tops if it has them). Its a pain starting out with doors that sag or seals that are screwed. Also, if the seals are bad now, its likely they have been for a while and there's gonna be rust/rot/mold that goes with it.
Find out why a car has a salvage title. Mine has one, and I was told it was because of an overly brutal police search of the interior that destroyed the seats and carpet. Well... when I tore out the interior I realized this car has been whomped on the rear end pretty dang good. If you don't know why, assume the worst. Don't be hopeful that it was just water damage.
Start out with the engine you want. I've got the 305 TBI and don't have the money to switch it out. If you want a 350, start with it. You'll be much happier.
Biggest thing is don't wish the car to be something its not. There's way too many third gen's around to settle for something less than you truly wanted. Don't fall in love with any specific car unless it really deserves it.
Old Jul 1, 2009 | 04:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its been said, but first, above all else, is rust. If you find anything serious, forget about the car. Rust hides and if you can see rust, chances are there is more you cant see
wiring. Under the hood and under dash will dive you a good idea if somebody have hacked up the wiring. Wiring gremlins can be really tough to fix if somebody has f-ed with the wiring.
Make sure the body is straight, bode seams, bumper to hood and decklip line up well. You can usually tell if the car was hit by how the body lines up.
After that its a personal taste.
Old Jul 2, 2009 | 03:19 PM
TREK's Avatar
Car: 1979 vette
Transmission: th350
check for RUST, pretty much everything else is fixable. i would diffantly check the floors front to back and for any major collisions. and make sure the water didnt get up into the wiring or anything electrical like the computer.
midge54
Sep 2, 2020 07:13 PM
theurge
Aug 21, 2015 12:46 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Dquickshift
Aug 12, 2015 06:21 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
