Hood crease.
Old Aug 4, 2009 | 11:49 PM
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Transmission: TH700r4
Axle/Gears: 3.43
Hood crease.
I have a crease in my hood, and I was wondering if I can cut the bracing underthe hood just where the crease is so I can fix and stregnthen (sp) the hood. Any help?
Sorry if this topic gets posted multiple times, I don't mean to but the iPhone wasn't letting me his post, if it only posts once, don't mind this.
Old Aug 5, 2009 | 11:15 AM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
Re: Hood crease.
Some hoods you can unbolt the bracing. I dont know for certain if this is possible with the thirdgen hoods or now. If you DO have to cut the brace, make sure you weld something in there if you take a whole piece out. These hoods are flimsy already. Notching it for something like an intake is one thing, but chopping a whole section out...is not something Id leave out for long
Old Aug 5, 2009 | 08:20 PM
Derth Deboblo's Avatar
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Re: Hood crease.
To anwser your question, No. If the crease is bad enough that you would have to cut the hood bracing to fix it, get a new hood. Hood's are cheap. Unless you're talking about the ALWAYS over priced 4 vent gta hood. Where are you located? I have a base (black) Firebird hood from my '91 I'd be willing to let go of.
Old Aug 5, 2009 | 09:09 PM
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Axle/Gears: 3.43
Re: Hood crease.
Aw, ok, I'll go that.
I have two hoods, both have dents, I think the org hood I can het to without any cutting, but I have a power bulge hood with a crease. How much you want for it? I'm in California.
Old Aug 5, 2009 | 09:40 PM
Stephen's Avatar
Car: 87 GTA
Re: Hood crease.
You certainly can cut the underhood bracing out. Fix the hood skin, then weld the bracing back in. Like FYRCHKN did, building his own custom hood.
https://www.thirdgen.org/forums/fabr...tor-build.html
Keep in mind, that the bracing isn't really welded to the skin, but rather.....Has an epoxy filler that cushions & supports the skin, more than actually adheres.
Old Aug 6, 2009 | 01:31 PM
1Aauto's Avatar
Former Sponsor
Re: Hood crease.
That's a cool article Stephen.
Old Aug 7, 2009 | 02:19 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Hood crease.
if I were you, I would use something like this to fix the crease/dent http://www.harborfreightusa.com/usa/...bCategoryName=
Are you in Southern California?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
