question about ground effects on Z28
Old Aug 12, 2009 | 12:41 PM
razman340's Avatar
Car: 1985 Z28
Engine: 305ci 4barrel
Transmission: 5-speed
i'm getting ready to re-paint the ground effects on my 1985 Z28. car is black with gold accents. i have decided to paint the ground effects black also. question is this: would it be better to remove them from the car, prep and paint, and then replace them. or tape and paint them in place? how involved is it to remove them? since i'm changing color, i would think i would get a cleaner paint job if they were removed for paint. has anyone here done this recently? thanks, rick
Old Aug 12, 2009 | 12:55 PM
youngc_87's Avatar
Car: 92 Camaro RS
Engine: 305 TBI soon to be 5.7 vortec
Transmission: WC T-5
Axle/Gears: Richmond 4.10
Re: question about ground effects on Z28
if your changing the color of them it would be best take take them off in case you have any rust forming below them that needs repaired. The only problem you may run into is the ground effects are sometimes brittle and might break. If you start running into theis problem then it's best for you to just leave them on and do it on the car
Old Aug 12, 2009 | 03:29 PM
razman340's Avatar
Car: 1985 Z28
thanks, yeah, i agree, that removing them would probably be best. assuming they aren't too brittle, are they easy to remove? are they bolted on, clipped or what? thanks
Old Aug 12, 2009 | 06:27 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Not fun
The main areas to worry about are the two long screws that reside under the Z/28 emblems (because you might break the emblems when you pry them off) and the rear of the rocker FX has a funky slide clip on the back in '85 you have to carefully pull away without breaking anything.
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
