t top lock swat
Car: I love my 91 camaro rs
Engine: V8 305
Transmission: Automatic
t top lock swat
I bought some new t tops and was wondering if anyone knows how i can swap the locks out so i have the same key.
Re: t top lock swat
Yes, it's a very easy job. First of all you need to remove the release handle and the black trim piece. After that, you will have easy access to the lock cylinder which is held in place with a clip on the back. Just remove the clip and swap the cylinders.
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Re: t top lock swat
You know. I have wondered this for years and never got around to asking, i have a replacement T-top that I have been rocking for years and i wondered if I could replace the lock cylinder. Thanks !
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: t top lock swat
I replaced the lock on a t top I replaced. I did the same as described, but I had to grind the rivets that held a shroud that protected the lock. Probably to keep thieves from accessing the locks.
Re: t top lock swat
Yes, there is a piece riveted around the cylinder but you can actually bend it out of the way and push it back in place once you swap the cylinders. You don't have to drill the rivets out if you don't want to.
Re: t top lock swat
I didn't know there was a way to bend the shroud out of the way, so I took a die grinder to it. Oh well, water over the dam. After I assembled the t top, it is not apparent.
1992 Trans Am
May 10, 2023 07:19 PM
gixxer92
Sep 1, 2015 04:32 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
