factory fiberglass hood underside removal
Subscribe
Sep 22, 2009 | 07:47 PM
has anyone ever removed the underside frame work on a factory fiberglass hood and made it into a pin on? mines coming apart in the back coners and the frame is cracked in a few places. and id like to get some more weight off the front end
Reply 0
Sep 23, 2009 | 05:08 PM
Re: factory fiberglass hood underside removal
I removed most of the understructure on my steel GTA hood with a cutoff wheel
Its not as heavy as youd think. I needed the space so I had no choice
Reply 0
Sep 23, 2009 | 05:54 PM
I'm guessing it will loose it's shape if you separate the two halves. IIRC, they were discontinued because they tended to separate on their own so hood pins might be a good idea for an intact hood anyways.
Reply 0
Subscribe
