Where to get a hood like this
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Where to get a hood like this
So I just get a normal camaro hood, from any model and put the blisters on them?
In your own respective opinions, do you guys think the louvers or the blisters look better?
Car: '91 camaro z28,imsa widebody
Engine: 383 ci l98,lt1 induction
Transmission: race built 700r4 , ratchet shifter
Axle/Gears: 342;1 detroit true trac diff
blister bonnet, but cut the bonnet under the blister,cut out the immitaion grill and replace it with mesh.... it'll let the under bonnet heat out.... it works!!!!!
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
83-92 are the same for the the irocz or z28 cars, the hood have indents in them so you can mount either the early model hood louvers, or the later modle hood blisters like the ones you have pictured.... best cheapest would be craigslist.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
82-84 Z28 hoods are NOT the same as the 85-92 hoods and you can not install 91-92 hood blisters on an 82-84 hood.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
