89 firebird headlights
Old Oct 1, 2009 | 10:48 PM
stoning_volcom's Avatar
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
is is possible to put 91 firebird headlights in my 89 firebird formula. Like the entire assembly
Old Oct 1, 2009 | 10:53 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: 89 firebird headlights
Yes. You'll need to swap the nose from a 91-92 also.
Lon
Old Oct 1, 2009 | 10:56 PM
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
and is that all? just the bumper? or is there more
Old Oct 1, 2009 | 11:39 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
The 91-92 headlight assemblies use a smaller headlight with a different plug so you will have to get 91-92 headlight pigtails. Also, you'll need 91-92 turn signals with pigtails. We have everything you need available on our site if you're interested in converting over to the 91-92 front end.
Old Oct 2, 2009 | 12:40 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
you would be able to do it if you swapped the nose. If you just try to change the assembly and motor they won't fit correctly. also im no electrician but the wiring may not match up correctly because the body changed.
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:53 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
