T-tops problems????
Old Oct 14, 2009 | 11:52 PM
madbomber824's Avatar
Car: 1986 Camaro
Engine: 350-Carb
Transmission: 700-R4
T-tops problems????
I have 1986 camaro with t-tops. I first bought some t-top seals to replace my leaking ones when i noticed they were about 2 inches to long across. So i returned the seals. I also bought a new headliner to replace my old crappy one and found out it didn't fit! I was comparing with my friend's 1988 camaro with t-tops and i noticed that his t-top bar is bolted in and my t-top unit is rivited in. Did they use different styles some years? So what t-top headliner and t-top seals do i buy?? Thanx Kevin
Old Oct 15, 2009 | 12:16 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: T-tops problems????
IIRC, there was an aftermarket T-Top conversion that has different dimensions. I think the area along the front is set back farther from the window on the aftermarket conversion.
Old Oct 15, 2009 | 10:28 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
...There are 2 sizes for t-tops.
Factory t-tops & aftermarket "dealer" t-tops.I forget the company name,but they did the aftermarket conversions.
Please search "t-top leaks".."leaky t-tops".. etc..
I BELIEVE the aftermarket t-tops are a few inches shorter in the front-to-rear measurement..??..
OR--you can ask your supplier how to determine which tops you have.
Some ppl like 1A Auto,some like Hawks (both are trusted sponsors for the TGO web site),,etc.
I wish you luck on your journey!Leaks suck...some ppl say "That's the way t-tops roll" some never have//had problems........
Old Oct 15, 2009 | 10:58 AM
1Aauto's Avatar
Former Sponsor
There were factory T-Tops and also Cars & Concepts T-Tops. It sounds like you have the cars and concepts version.
Old Oct 15, 2009 | 12:58 PM
Car: 1986 Camaro
Engine: 350-Carb
Cool, thanx for the info. I did not know that. Is this usually more valuable in cars or why did they originally install them?
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
g.l.mos
Aug 22, 2015 12:02 AM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
