rust helper
Old Oct 26, 2009 | 03:03 PM
82z28 wrencher's Avatar
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
rust helper
I know rust is going to happen if i drive in the winter but what are some ways to slow IL's salt from eating my bird
Old Oct 26, 2009 | 03:14 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: rust helper
rubberized under coating
Old Oct 26, 2009 | 03:48 PM
Twin_Turbo's Avatar
Re: rust helper
Powerwashing the underside every couple of days.
Old Oct 26, 2009 | 06:52 PM
zzzzknightzzzz's Avatar
Car: 1992 RS CAMARO 25TH ANNIVERSARY
Engine: 305 TBI
Re: rust helper
or just done drive on wet or nasty days but if its your only ride keep it clean and in check with washing
Old Oct 29, 2009 | 11:27 AM
Car: 84 Trans Am
Re: rust helper
will some ruberized undercoating in a can work? and underbody washes ill do for sure.
Old Oct 29, 2009 | 12:24 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: rust helper
if you use it in a can, you need to get it up on a lift so you can move the can around and make sure you get it into every little spot.
I used it on my car when I did a repair, and i had to go back and fit a little spot that i missed because it was hard to move around.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
