Hood Advice
Old Nov 25, 2009 | 03:48 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Hood Advice
Help me decide what to do for a hood please. Right now I need to fix the 4" cowl I have. It was bondoed on poorly and its all cracked now, so no matter what, I need to do something. The guy I got the car from cut a hole in the original fiberglass hood and just stuck the cowl on it. Should I just repair the hood, done the right way this time, and cut off some the cowl, down to like 1.5" or so tall or use my other good iroc hood just as it is with new paint. If I were to use the iroc hood, maybe do something like heritage stripes also. Its silver if it matters.
Old Nov 28, 2009 | 11:15 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: Hood Advice
I think this is a personal preference call that you have to make. If you want to use the cowl hood, no doubt you should tear it down to a hood with a hole in it and a cowl and fix it right. Remove all bondo and see if you are left with a reasonable task of repairing it.
Hotrodboba400
Dec 10, 2019 07:07 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
