Front windshield cracked!!
Old Jan 12, 2010 | 06:11 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
I need some help fast. My front windshield on my '88 S/C is cracked and getting worse quickly. Is there any way to fix this or should I just get a new windshield? I only have liability insurance on it. Is anyone aware of any place to get a good deal on a windshield?
Old Jan 12, 2010 | 07:43 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Front windshield cracked!!
You're probably just gonna have to replace it. Google windshield replacement or something like that an you'll find a few "discount" places.
BTW: your sig is awesome!
Old Jan 12, 2010 | 09:00 PM
Engine: 350 S/B
Thanks for the info. I'll try that.
Old Jan 12, 2010 | 09:18 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Depending on the length and location of the crack it may be repairable. There are many places that do that by filling the crack with a clear bonding material. If it's too bad, then it will need to be replaced.
Some have had luck stopping a crack from spreading by drilling a tiny hole from the outside into but not through the glass at the tip of the crack. This creates a "dead-end" for the crack.
Good luck.
Old Jan 12, 2010 | 09:27 PM
Engine: 350 S/B
I'll try that tomorrow, but it's about half way up the window starting from the bottom. Not good!
Old Jan 12, 2010 | 09:32 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
I just had the windshield on my '89 Firebird replaced a couple of months ago at Speedy and asked about those temporary repairs for rock chips, etc. I was told that will buy you about a year and then the windshield will need to be replaced.
The funny thing is that I asked about the cost of a windshield for my '88 GTA, which will not be covered by insurance (I can get one from a wrecker for about $145, pulled) and the guy at Speedy said a new replacement is only about $120
Old Jan 12, 2010 | 11:59 PM
Axle/Gears: 3.08
To many vaiables to be general about the results. Depends on the extent of the damage and the quality of the repair. Rock chips and small crack repairs can last years and years. Often right up to when the windshield must be replaced due to normal pitting causing unsafe glare at night.
If the damage is more serious a repair can be a roll of the dice or even impossible. With the damage that Shadyredeyes describes, I'd expect most places would say time for a new windshield.
PS; be sure to watch the quality of the windshield replacement. Some shops give a cheap rate or increase profit by taking short cuts. Examples . . . not using OEM type weatherseals or low quality ones (yields poor fit and water leaks), incorrectly prying the windshield out and damaging the windshield frame and even chipping the paint (yields rust and corrosion and future body work), not using the proper adhesive (yields water leaks and weak fit).
I've seen one shop damage the windshield frame so bad from prying the windshield out to save time, that they covered up their poor workmanship by using an extra wide weatherseal around the frame! There should also be no need for prying a windshield if the removal is done properly.
Old Jan 14, 2010 | 12:22 AM
Engine: 350 S/B
I'm planning on drilling the windshield tomorrow to prevent the crack from spreading. But I shall soon look to replace the windshield. Anyone know where to get a good deal on one?
Old Jan 14, 2010 | 11:10 AM
50bmgshooter's Avatar
usually any crack in your windshield that is inside the sweep of the wipers will fail you on a inspection
Old Jan 14, 2010 | 12:05 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Yeah I second the last reply.....I had to replace the windshiel on my SUV because it would have failed inspection....just choose a reputable shop....and remember, you get what you pay for.
Old Jan 14, 2010 | 04:40 PM
Engine: 350 S/B
I tried to drill the windshield today and that didn't work out too well. It just continued to crack as I tried to drill it. Looking for a new windshield as of.............now!
Old Jan 14, 2010 | 05:01 PM
RU1NER's Avatar
Do they make replacement windshields with built in antenna's like in an 81 malibu (friend has one and had it replaced).
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
kyleb24
Aug 15, 2015 08:24 AM
