new upper and lower door hinge repair problem
Old Jan 16, 2010 | 07:52 AM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Last night I replaced my passenger side door hinge pins.The door was of the car and I used a replacement lower body side hinge(used) when I bolted the door back on it drags on the bottom.I adjusted the hinges as far as possible and it stiil drags.How do I fix this? can the hindges be bent that far off?
Old Jan 16, 2010 | 08:13 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: new upper and lower door hinge repair problem
If the hinges are really bent than a auto body shop should have a door re-alignment tool to bend the hinges back into place. Takes about 10 minutes to do. Had it done once before replacing the upper pin on mine.Best place to get hinge pins ,etc is Topdownsolutions on line.They make allot of hard to find pieces for our cars. They even sell the alignment tool for like $25.00.
http://www.top-downsolutions.com/
Old Jan 16, 2010 | 09:51 PM
howy03's Avatar
sounds good,I did buy the hindge pins from TDS.I just wasnt sure if the alignment tool would bend it up that much.Im about 3/4 inch low at the latch end of the door.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
mustangman65_79
Aug 8, 2015 12:07 PM
