removing rear gfx and bumper on my 91 t/a
Old Jan 24, 2010 | 09:55 AM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I have a 1991 trans am 'vert and I wanted to remove the rear bumper along with the ground effects that connect to it behind the rear wheels. The haynes manual is silent on this matter lol. Any tips/pointers? Thanks!
Old Jan 24, 2010 | 10:09 AM
Stephen's Avatar
Car: 87 GTA
Re: removing rear gfx and bumper on my 91 t/a
Only pointers I can offer are to get under you car & LOOK. Look in the rear of the wheel wells. Pull the interior panels back & look under those as well.
One good look & all the fasteners are very obvious. That is how I found everything on a 89 GTA. Never once did I even consider looking in a book to tell me.
Old Jan 24, 2010 | 12:02 PM
Engine: LB9
Aw c'mon man you're making me feel like an idiot. LOL
But in all seriousness that's the same mentality I had when I was taking my front end apart. I ended up cracking one of those front gfx pieces (that are a PITA to get a replacement of) that attach to the fender in between the nose and front wheels. Turns out GM had the genius idea to glue that piece to the fender, despite me having removed ALL fasteners. I wanna avoid that this time, so that's why I'm asking.
EDIT: And the 91-92 ground effects are a bit different than the ones on your 89 GTA.
Old Jan 24, 2010 | 04:56 PM
Stephen's Avatar
Car: 87 GTA
Camaro fx are WAY different. My GTA is my first Firebird. 84, 86, 90, & 92 Camaros before the GTA.
If there was adhesive/glue in there, I don't think GM put it there. Never seen adhesive/glue in any of mine before.
If your front fx pieces between the wheel well & nose are both in good shape, treat them like gold. You DO NOT want to have to go looking for those 91-91 'bird fx pieces.....They'll be busted for years, before you find any!
Old Jan 24, 2010 | 06:05 PM
Engine: LB9
That adhesive was original GM stuff because the car has never been taken apart before. And if you'll see the construction that's pretty much the only way you could get the piece to hold onto the fender. Yes I know those are hard to find, and I'm not sure why you're mentioning camaros since they have nothing to do with what I'm looking for.
Does anybody here know how to remove the rear bumper/gfx pieces off of a 91-92 firebird? Anybody?
Old Jan 24, 2010 | 06:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yeah, the 91-92 bird gfx have an adhesive strip on teh top holding them to the fender, no screws there like the earlier 82-90 one do.
the rear parts are all bolt on, a couple screws under the car, i believe 3 inside the car, maybe one in teh wheel well and thats it. Just dont force it. If it seems stuck somewhere, there is probably another screw.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
3rdgenparts
Aug 8, 2015 07:09 PM
