Question About Primer
Old Feb 3, 2010 | 10:06 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Guys I'm getting ready to pick up some pieces for the front of my car from the wreck, and the odds that I can find a like color donor car are slim.
Now, over the summer while I save up for a paint job I DO NOT want to be driving around with a white Camaro that has a red front end.
Regarding priming all the donor pieces, what is the best method to make sure that when I do get my paint job, it adheres properly?
What is the proper technique for sureface prep before priming? Do I need to sand the primer agfter it goes on or just spray it and let the paint shop worry about the rest? Any particular brand of primer I should be using? Should I use a spraygun (Out of the question) or would a spraycan do the trick?
Old Feb 3, 2010 | 11:33 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: Question About Primer
Primer is not waterproof... Driving around with a primered front end for the summer is probably ok, just plan on stripping it all off and repriming before you paint and don't be surprised if moisture has gotten through the primer and caused some surface rust... Think you'd be better off driving a white car with a red front end.......
Old Feb 4, 2010 | 12:25 AM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
The best method for you is to sand the panels with 320 grit sandpaper and prime with PPG K36 it is a water proof primer and you will not need to strip back to metal if you are primeing the front bumper then you need to use a flexable prime
Old Feb 4, 2010 | 12:47 AM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
if your going to save up for a paint job let the painters do their job and prime it them selves...
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
