differance in fenders
Old Mar 3, 2010 | 09:25 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
im going to eventually need a driver side fender on my iroc vert. Hawks has it but my question is whats the difference between a regular fender and the one for a convertable. i figured they would be the same but apparently im wrong
http://www.hawksthirdgenparts.com/ca...lectprice.aspx
Old Mar 3, 2010 | 11:01 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: differance in fenders
Im not sure about Camaros but Firebirds have the same fenders doors bumper and hood as the coupe
Old Mar 3, 2010 | 11:27 PM
89rsvert's Avatar
Car: 1989 Camaro convertible
The convertible fender is the hardtop/t-top fender with the bottom cut off. ASC used regular fenders, they just cut the bottom off, and installed the bracket. If you have your old convertible fender, it is very easy to cut the t-top/hardtop fender bottom off. Cut off wheel works great. You have a bracket on your convertible fender that is riveted on at the bottom. Drill those rivets, drill the holes in the new fender and rivet it on. The ground effects cover all the cutting and modifying. I have done this many times. Check out the convertible forum, and there are pics. Good luck to you!
morrow
Jan 13, 2024 12:29 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
