Removing IROC hood louvers for painting
Old Mar 7, 2010 | 12:54 PM
Jammin'Trey's Avatar
I recently got a mint IROC hood locally for 60$, all of the louver studs are in tact, How can I remove them without breaking a single stud?
I was thinking of tanking a dremel and slotting the bottom of the studs so i can hold the studs with a regular screw driver while i wrench off the nuts..
Any one have other suggestions? Thanks, Trey
Old Mar 7, 2010 | 01:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Removing IROC hood louvers for painting
Be worth a shot. That plastic will be fragile. A bit of lubrication wouldn't be out of order.
JamesC
Old Mar 7, 2010 | 03:18 PM
Ok, I might spray a little wd40 on them before i loosen them up
Old Mar 7, 2010 | 03:40 PM
toomany's Avatar
If you are going through that much trouble, why not just cut the nut itself? A pack of 10 at Napa is only a few dollars.
Old Mar 7, 2010 | 04:37 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
good luck those studs are the most fragile plastic on the face of the earth lol all but 2 on each louver where in tact on mine after removing them
Old Mar 7, 2010 | 05:34 PM
Oh yikes... I think Im going to wd40 them a little, let it soak in really good.
Slot the bottoms so I can hold the stud with screwdriver and very slowly take them off
Old Mar 7, 2010 | 06:46 PM
AmorgetRS's Avatar
I am not sure how much more helpful it would be, but try a product that was designed for loosening tight bolts like liquid wrench or PB Blaster.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
