Tiger Hair... ugh
Old Mar 14, 2010 | 01:06 PM
Jammin'Trey's Avatar
Tiger Hair... ugh
I recently bought some tiger hair to patch the quarter on my 86 iroc.. This stuff looked like a great idea and was easy to use... Yea, its really hard to use, I had problems with it trying to continuously drip off my quarter panel... It did not want to stick to the car very well. If anyone has some tips for using it please post!
Old Mar 14, 2010 | 02:28 PM
Samdweezel05's Avatar
Re: Tiger Hair... ugh
Surface has to be clean. Use 80 grit to scuff up where you want it to stick. Tiger hair doesn't run or drip. Not sure what your doing with it.
Old Mar 14, 2010 | 03:18 PM
I figured out what the problem was.... Its 43 degrees in my garage. Which is warm to me conisdering we have had a 0 degree winter. I got a heatlamp on the panel, keeping it at 100 degrees now. Working great! I did just put a second coat of it on to finish where the original dripped.
I have also been using bondo hair hardner cream instead of the blue Tiger hair hardner because I dont have any. Apparently they are the same thing.. Its curing good now with heat... Like within 8-10 minutes its pretty hard
Old Mar 14, 2010 | 08:40 PM
Tonglebeak's Avatar
Car: 1986 Camaro Z28
Engine: 305 4bbl
I just recently did my first bodywork job, which was patching a bumper that had a hole in it from a collision. I used the tiger hair. I learned very quickly what it was all about. I didn't even use a fiberglass cloth to back it (the hole had a 3inch diameter), and it's still holding together. I will admit though, there are still a few divets that appear to require regular body filler, but I was told that it was fine the way it was, and not to worry about it lol.
Old Mar 24, 2010 | 02:16 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
its good stuff, tigerhair. I still like the evercoat kitty hair better. Did you get long strand or short strand?
SBlackfoot
Jun 27, 2003 06:32 PM
Trans-it
May 2, 2003 01:05 PM
Trans_AM_88
Mar 13, 2003 06:04 PM
ClarionedCanuk
Oct 22, 2002 08:36 PM
ninety1TAgta
17
Oct 14, 2002 11:43 AM
