replacing rotor,
Old Apr 12, 2010 | 06:46 PM
FFDP's Avatar
replacing rotor,
well! i just replaced the dist. cap and am proud it starts up better but not perfect yet, any advice on the rotor? **** it should be getting done in a few weeks?
Old Apr 12, 2010 | 08:15 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: replacing rotor,
I remove the NEG batt cable--I don't have ECM, just a radio & clock to reset.
Take off the dist cap & lean it out of the way.
If you can, leave the plug wires on. If not, mark them so you know where they go.
The rotor is held in with 2 small screws or 2 very tiny bolts.
Notice how the rotor is positioned.
Remove the old rotor.
Place the new rotor on just how the old one came off. Some come with new screws already in the rotor.
Snug it on. DON"T go too tight-- the holes will strip.
Replace the dist cap, & any wires you removed, putting them where they came off.
Make sure the dist cap is locked down.
Connect the batt cable if you took it off.
Start it up & go cruisin'!!
Old Apr 13, 2010 | 06:17 AM
FFDP's Avatar
thank you kind sir!
but.. alas, more problems have been found, the air to fuel ratio and the timing arent doing that great.
the timing I know little about, but the air to fuel ratio i'm assuming is with a computer?
Old Apr 13, 2010 | 03:33 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Why is this in the BODY section
Old Apr 13, 2010 | 08:19 PM
FFDP's Avatar
why not then kris? :X
maybe can get it moved then to the right thread? heh
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Winchester1094
Aug 18, 2015 10:23 AM
