t-tops leaking
Old Apr 16, 2010 | 01:16 PM
j.rodz's Avatar
Car: 1985 iroc-z
Engine: 305 tpi
t-tops leaking
I just had my 85 iroc-z painted. ordered new t-top weather strippings for it and had them installed at the body shop but when the it rains water still leaks in!
Old Apr 20, 2010 | 07:38 PM
87_Injected's Avatar
Car: 2010 2LT RS
Re: t-tops leaking
I read that if they are aftermarket weatherstrip then they will most likely leak. Factory ones are the way to go but cost more $$. I'm sure someone will correct me if I'm wrong. Also I read that if they still leak even with new factory weatherstrip, then you could have other issues on hand.
Old Apr 21, 2010 | 07:01 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Re: t-tops leaking
Where is the water coming in from? At the door glass/t-top seam? Try adjusting the mounting brackets to tighten the t-tops more against the weatherstripping.
Old Apr 21, 2010 | 08:40 AM
BakerUSAF 86T/A's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 350 Small Block Bored .30 to a 355
Axle/Gears: 3:73
Re: t-tops leaking
Yes, figure out where exactly the water's coming from and update us!
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
blackandblue02
Sep 10, 2015 08:19 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
