need help
Old May 4, 2010 | 01:04 AM
86 irock z28's Avatar
Car: 86 irock z28
Engine: 305tpi gt 350 though then ls
Axle/Gears: lol no clue new to cars
need help
need help im a new camaro owener i have a 86 z28 iroc z28 yes it is white and sorta rare i k lol any ways i need some help i curecting some small problems on it bye swaping out parts on my other 91 rs but iv run in to a problem i cant figer out how to put my air dame frome the rs to the iroc i have a new after market fan witch for now on cool days will pull enough btus to keep it cool but it tends to heat up on thees hotter days pleas help lol i am new to working on cars so pleas spell it out in stupid vs
Old May 4, 2010 | 01:22 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: need help
if both of your camaros are TPI, then it still won't work... 86 is a MAF setup which I believe uses a different air duct than the 91 which is MAP... you will have to buy an air duct for that particular setup... now on your fan switch.. I have no idea what exactly you're trying to do.. on the car that you say is getting warm, have you changed the coolant, replaced the thermostat and checked the timing to make sure it's right?
Old May 4, 2010 | 01:37 AM
JT's Avatar
JT
Community Administrator
Re: need help
I think the author of the thread is speaking about the air deflector on the underside of the front end. It will play a significant role on cooling the radiator.
