What's the easiest way to replace a door lock cover.
Old May 6, 2010 | 11:58 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
You know that black cover which covers the door lock where the key goes in? I've got a cracked one. What's the easiest way to replace that? Do you need to remove the lock or is there a way to replace the cover without removing the lock?
Old May 7, 2010 | 03:55 AM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Re: What's the easiest way to replace a door lock cover.
You have replace the lock cylinder. Pull the door panel theres a clip that holds the cylinder to the door and theres a rod that goes through the hole on the end of the lever on the back of the cylinder with a plastic clip that rotates and clips on the rod to hold it in the hole.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
