3rd Gen T top compatibility
Subscribe
May 25, 2010 | 02:38 PM
Are all 3rd gen trans am T tops compatible?
Reply 0
May 25, 2010 | 03:06 PM
Re: 3rd Gen T top compatibility
Not quite. 1982-1984 t-tops have a hook style latching system. 1985 to 1992 cars use a pin style latching system to hold the t-tops in place.
Reply 0
May 25, 2010 | 03:10 PM
Also the pin styles vary in diameter depending on year
Reply 0
May 25, 2010 | 03:13 PM
Quote: Also the pin styles vary in diameter depending on year
Do they? I knew there were other differences such as mirror vs. non-mirroed finish, tint differences and of course the outer weather stripping on 90+ cars.
Reply 0
May 25, 2010 | 03:17 PM
There are some differences in t-tops. They could be glass or lexan, which you should be able to just adjust the mounts and they will work. Also I believe the newer years 90-92 have bigger pins that hold the tops in place but that wouldn't be a problem if you can get the plastic mounts behind the A and B pillar moldings and switch those over as well.
Reply 0
May 25, 2010 | 04:43 PM
Quote: Do they? I knew there were other differences such as mirror vs. non-mirroed finish, tint differences and of course the outer weather stripping on 90+ cars.
yea..theres some that are like pencil sized then theres some that are like kindergarden crayon size
Reply 0
May 25, 2010 | 07:53 PM
Reply 0
May 25, 2010 | 07:55 PM
Quote: yea..theres some that are like pencil sized then theres some that are like kindergarden crayon size
the ones on my 85 are about kindergarten crayon size...but they don't leak...and I sprayed a hose at em! lol!
Reply 0
May 25, 2010 | 08:43 PM
I've got an '84 Berlinetta, it's pin style with large diameter pins. This isn't stock? The tops have the Vin scribed into them though.
Reply 0
May 25, 2010 | 10:31 PM
Don't forget the aftermarket T-Tops..
My '83 has C&C T-tops that are a different size then factory ones.
Reply 0
Jun 2, 2010 | 02:19 PM
My 83 Camaro has a C&C T-tops, any suggestion on where I can buy replacement weather stripping for it?
Reply 0
Jun 2, 2010 | 02:24 PM
Quote: My 83 Camaro has a C&C T-tops, any suggestion on where I can buy replacement weather stripping for it?
As far as I know no one makes weather stripping for C&C T-Top cars.
Reply 0
Jun 2, 2010 | 02:54 PM
http://www.sunroofdoctor.com/
They have C&C weather stripping.
Reply 0
Jun 2, 2010 | 03:44 PM
sorry to thread jack but any idea of who or how much it would run me to t-top my hardtop. ive got 2 firebirds, one i keep completley original and the other is just a mod car. But i dont know where to even start to find someone to cut the roof out.
Reply 0
Jun 2, 2010 | 04:09 PM
Quote: sorry to thread jack but any idea of who or how much it would run me to t-top my hardtop. ive got 2 firebirds, one i keep completley original and the other is just a mod car. But i dont know where to even start to find someone to cut the roof out.
get a t-top roof assembly from a j-yard and use it to replace your hardtop.
Reply 0
Subscribe
