Best way to remove surface rust on hatch window frame?
Old Jun 20, 2010 | 09:31 PM
Flightoficarus's Avatar
The attached picture I've uploaded will make it look worse than it really is, but I have some surface rust on the metal window frame of my Firebird's hatch that I'd like to do away with.
Take a quick look at the pic. Should I try some bondo? or replace the frame? (if that's an option)
Attached Thumbnails Best way to remove surface rust on hatch window frame?-hatch.jpg
Old Jun 20, 2010 | 09:37 PM
toswald84's Avatar
Car: 84 Z28
Engine: Carbed 305
Re: Best way to remove surface rust on hatch window frame?
sand it and respray it black
Old Jun 20, 2010 | 09:44 PM
irockidz28's Avatar
i had the same problem on my car i just fixed a few weeks ago tape off around the painted areas pick up some red scotch scuffing pads get the rusted areas cleaned up and scuff the areas with good paint as well then i did two coats of duplicolor filler primer which helped smooth it out a little bit then i did 3 coats of duplicolor trim black and it came out great
Old Jun 21, 2010 | 12:39 AM
So basically, I should just treat it like I would a spot on the body?
Sand down the rust completely
Prime the bare metal
Paint it?
Truth be told, I've never done it before, but I figure the window frame is a good spot to start :]
Old Jun 21, 2010 | 12:47 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Id use some appliance epoxy paint on that small strip, will last forever, awesome paint but it like 2 days between coats so get it right the first time.
Old Jun 21, 2010 | 01:14 AM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
haha i just finished watching a Musclecar rerun were Rick did this to a green third gen camaro. then i get on here and find this. alright what he did is he taped the window and sanded the trim with a red scotch brite. then primered it and sprayed it with Trim Black.
Old Jun 21, 2010 | 01:11 PM
irockidz28's Avatar
hahaha i guess i had the right method then!!
Vintageracer
Jan 10, 2020 05:33 PM
hectre13
Sep 8, 2015 03:38 PM
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
