Power window question...
Old Jul 4, 2010 | 06:51 AM
m3456y's Avatar
I tried searching and did not find the answer -
The car is a '83, drivers window only goes down half way - then sounds like the half moon gear is stripped. Lots of mechanical clicking, and I can't force the window down as it's happening. It does go up and when it gets to the top - same mechanical clicking. I had the door apart, but could only lift the door panel up as I could not unfasten the top clips because of the window not going down all of the way.
Could something be out of adjustment? I do have a new regulator motor to put in, but I'm not sure that is the issue. Any suggestions would be appreciated.
Old Jul 4, 2010 | 08:31 AM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Re: Power window question...
Do you only have the motor? Or do you have the whole regulator? It's probably the regulator that's going bad.
Old Jul 4, 2010 | 08:53 AM
m3456y's Avatar
I have the whole regulator. It works fine until it gets halfway down - then sounds like the gears are not meshing. And when it gets to the top - the motor wants to continue running...causing the gear to skip over the teeth.
Old Jul 5, 2010 | 01:56 PM
m3456y's Avatar
anyone have this experience that can help me? Or... how do you remove door panel when window won't go down?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
