need help on removing ground effects
Old Jul 9, 2010 | 10:37 AM
Friguy's Avatar
Car: 1989 Pontiac Firebird
Engine: Multiport 2.8L V6
Transmission: 700r4 with Shiftkit
Axle/Gears: All Stock
Hey whats up?
Well I am trying to remove the fender on the passenger side,but because the ground effect is on the fender,how do I remove it without breaking something?
it seems like its screwed on or glued,but I have no way of getting to it.any help would be good, Thanks...
Old Jul 9, 2010 | 10:57 AM
ms87iroc's Avatar
Car: white 87 iroc-z
Engine: 5.7 tpi
Axle/Gears: 3:27
Re: need help on removing ground effects
You have to take rocker emblem off it pops out and there is two screws behind it. Also the the rocker ground effect has to be removed completely, there is also speed nuts that have to be removed on the other side on quarter panel, you have to remove interior plastic arm rest panel in rear seat area to access the speed nuts, also underneath rocker and on top of rocker there is screws.
Frozer!!!
Jan 19, 2024 04:55 PM
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
