bent radiator support
Old Jul 16, 2010 | 07:31 PM
jaymoung's Avatar
Car: 1984 Camaro z28
Engine: 350 small block
Transmission: 350 Turbo
so i was pulling my z28 out some soft mud with my blazer and i hook up my towing strap up to what i thought was a towing pont but was my radiator support it was the center hole and it bent in it didnt damage anything but im not sure how to fix this try to bent it back out or cut and weld
what you guys think?
Old Jul 16, 2010 | 07:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: bent radiator support
how bad? pic? if its not hurting anything, leave it alone. Maybe try to beat/pull it back to shape.
Old Jul 16, 2010 | 10:26 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Remove the condenser and radiator and beat it back into shape with a hammer, supported underneath by a jack and a 2x4. If screwed up enough, your electric coolant fan won't work and you could overheat, among other problems. I just straightened mine this way (it's not a jack point, either). FYI, the towing points are in front of each front wheel, what looks like a loop in the area of where the sway bar connects to the body.
sheachopper
Jul 31, 2019 11:27 AM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
