Help Please
Old Aug 10, 2010 | 07:56 PM
89 IRoc Z 28's Avatar
Help Please
Hey guys,
I bought my Iroc last year planning on redoing the car but the other day i was working on my car and seen that the drives side floor had a rust hole in it and the floor is in bad shape just on the driver side so i was wondering on how hard it would be to replace the floor and if its worth it thats the big prob with rust it has some fender rust that can be sanded off. and if i can do the work my self..
Thanks for the help
Old Aug 11, 2010 | 12:11 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Help Please
Come on man,,, peace of cake. This is a messageboard, not a online merchant store. Its easy to find things. Go to google.com, type in what your looking for and instead of hitting search hit shopping in the upper center of the window. Then go to the list on the right hand side of the window and select "lowest to highest" for the best prices. But I did the work for you.
http://www.shopwiki.com/Floor+Pan+LH+82-92+Camaro-FULL
You'll have to go to the body shop or you can do it yourself if you know how to weld. Good luck bro.
Old Aug 11, 2010 | 03:09 PM
Re: Help Please
Thanks for the help never thought to check on google
Old Aug 11, 2010 | 03:14 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Help Please
I bought a donor car and cut it out. Your best bet if you have the cash though is to buy the new pan. It will be cleaner and a lot less work.
Old Aug 11, 2010 | 03:43 PM
Re: Help Please
. Its better that way too. It'll last you longer. If you do buy the new floorpan, clean off the whole area around the new pan and spray Rustoleum to prevent future rusting. It would be wise to clean and do the same in the wheel wells too.
