Emarrasing window noise
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Has anyone had a window problem when you raise them and they make a embarrassing screaching sound? Has anyone ever fixed the problem? Any advice would help.
http://www.youtube.com/watch?v=xu-2gfG6i-U
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Emarrasing window noise
Either the felt has worn off on the glass stabilzer or it is too tight.Either way you have to remove the door panel to replace/adjust it.The stabilzer is at the very top of the door.Just under the plastic trim at the top.There are 2 of them.
Sometimes when they are very dirty mine will squeek just a bit, but nowhere near yours.Maybe try cleaning the inside of the window.
OK. The stabilizers are the metal pieces with felt and are about 1 1/2 right?
What kind of head lamps do you got/
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
sjorgens
Oct 1, 2015 07:54 PM
