wheel well rust. what should i do
Old Sep 27, 2010 | 10:26 AM
wes'sirocz's Avatar
Car: 2005 silverado ss and 87 iroc-z
Engine: 350 vortec stealth ram comp cams
Axle/Gears: ford 9" 3.50
Im in the process of restoring my iroc. i have the front end and engine compartment done now im in the wheel wells. where all the seems are rotted away where the wheel well meets the back of the rear seats. Whats the best way to keep rust from coming back after i replace the wheel wells and some metal from behind the seats? the rust has always been an on going issue. I did the body once 5 years ago and that rust wasnt there. I fixed all the other rust spots now it decided to come out there. whats the best way to keep rust ferom coming back
Old Sep 27, 2010 | 10:33 AM
rusty rider's Avatar
Car: 86 IROC
Engine: 305 lg4
Re: wheel well rust. what should i do
Clean the area up really good and then coat it in POR 15.
Old Sep 27, 2010 | 11:07 AM
wes'sirocz's Avatar
ive used por-15 on other projects on this car and it has pealed right off in some areas.
Old Sep 27, 2010 | 11:13 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Did you follow the instructions (ie : Marine Clean, Metal Ready then POR15) ?
Old Sep 27, 2010 | 11:18 AM
wes'sirocz's Avatar
i normally grind away until bare metal then use acetone or prepsal to clean it then apply
Old Sep 27, 2010 | 11:28 AM
The metal is too smooth, it needs something to bond to the surface. That's what Metal Ready is for.
I tried painting it over rough sanded surfaces and it didn't hold up very well, but with Metal Ready it's tough as nail.
Old Sep 27, 2010 | 11:32 AM
wes'sirocz's Avatar
can you get metal ready anywhere?
Old Sep 27, 2010 | 04:49 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Anywhere they sell por-15..
Otherwise you can use phosporic acid, thats pretty much all metal ready is. Follow the same directions that you would for metal ready.
my86bird
Oct 23, 2015 12:20 PM
m00n420
Sep 11, 2015 02:39 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Stryker412
Sep 7, 2015 09:11 AM
