factory door gap specs?
Old Oct 7, 2010 | 10:29 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Iv looked in all my assembly manuals. Can't find them according to this 3 ring binder book there might be a fisher body book with all the body specs and tolerances.
Old Oct 7, 2010 | 09:10 PM
FueledSoul's Avatar
Re: factory door gap specs?
no body?
Old Oct 7, 2010 | 09:20 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
I'll ask my friend that owns a body shop.
I never even thought there was specs on it, just eyeball
& make sure the claw & latch work correctly, & the weather
strip seals!
Man, there's another lesson I learned!!
Old Oct 8, 2010 | 04:44 PM
Car: '87 Camaro
I stopped by his shop @ 4:30, guy @ my other friends auto repair across the street said they left @ 4:00 for the day!!! He NEVER closes early!!
CRAP!! Sorry FueledSoul!!
Old Oct 8, 2010 | 04:50 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I'm with havoc. Years ago I saw the specs on the gaps for F-bodies but I don't remember them. Even, straight all around, nothing too close or too wide and go.
Back then GM along with the other manufacturers didn't care too much about gaps. They couldn't even get the paint to stay on!
Old Oct 10, 2010 | 09:43 PM
FueledSoul's Avatar
lol... still theirs got to be some specs
FueledSoul's Avatar
it would be great if someone could scan a copy of the sheet if they find it... i got my doors half way bolted on i just need to see were the gaps should be
Old Nov 29, 2010 | 12:28 PM
Car: '87 Camaro
FueledSoul---
Get it figured out??
Yup, I know, it's been a looonnng time.
Old Nov 29, 2010 | 02:02 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
3mm
Old Nov 29, 2010 | 11:27 PM
FueledSoul's Avatar
Originally Posted by t-top havoc
FueledSoul---
No dice man...
Old Nov 29, 2010 | 11:39 PM
Car: '87 Camaro
keeslinger31--
Can you post the page? How did you get the info??
So I talked to my friend that owns the bodyshop.
He doesn't have anything with that kind of info-- just part #s & exploded views.
Old Dec 3, 2010 | 12:10 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I grabbed a 1985 Firebird service manual from work the other day and have been all over that thing trying to find the gap specs. None anywhere. Next time I'm in the shop "library" I'll look for a body service book. The FSM has a lot of body info in it but not gap specs.
3mm is the low side of unibody tolerances for that time period. Gaps are wider then that.
Old Dec 3, 2010 | 02:04 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Rule of thumb -- if you can stick your thumb between body panels, the gap is too big
Old Dec 3, 2010 | 03:03 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
That's a good one. I'll have to remember that one but not sure if it will work on 2000 up GM truck front ends. I've seen some pretty big gaps on some of those things.
Old Dec 3, 2010 | 04:26 PM
navy02ws6's Avatar
Yeah, guess it depends on the size of your thumb too. I've seen lots of 1968-82 Corvettes with poorly repaired body/frame damage that I can just about fit a foot between the quarter panels and doors (okay, not really, but you get the idea).
Old Dec 3, 2010 | 07:16 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I know what you mean. Seen some horrible work on those cars, but they fit rough new.
I've got a untouched 1954 Vette. The bottom of the right door sticks way out at the front especially. Most pics of these cars I've seen show the same thing.
BTW, my thumb is pretty big. Probably from a few hundred smashes with a hammer, and a little Arthur!
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
diana227vegas
Jul 8, 2016 12:27 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
