rear window swap
Old Oct 20, 2010 | 01:17 PM
bart6180's Avatar
Car: 04 silverado 4x4, 91 firebird
Engine: 5.3-silverado--3.1-tbi-firebird
rear window swap
i have a 91 firebird which is pretty much the base model, hardley any options on it, i have a rear window from a 91 camaro which has the defrosters on it, i can swap the windows pretty easily but how would i get the defrosters to work, would it be a power and ground to a toggle switch or is there more to it than that???
Old Oct 20, 2010 | 01:32 PM
Stephen's Avatar
Car: 87 GTA
Re: rear window swap
As far as the swap goes....The bolts are identical. Unbolt, swap, rebolt..... Simple.
On the defroster....I'm not familiar with the circuit enough to say yes or no. Ask over in the Electronics section about swapping a defrost hatch on to a non-defrost car. Might already been covered & found in the Tech articles or by doing a Forum search.
Old Oct 22, 2010 | 12:54 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I'm trying to do the same thing with my 91 T/A...I already have the switch and 3 switch panel (fog lamps, hatch release, rear defrost) from another car, there's also a rear defroster relay that must be used which I also got from another car. The relay is located directly behind the map pocket on the passenger side of the dash. I may have already had my dash out when I installed my relay, so I don't recall if you need to remove the dash to install it. Might be able to just remove the lower panel and access it from the back.
All the factory wiring should be in place to convert it, I found the harness for the switch and the defroster relay taped up behind their respective trim pieces in my car. I would assume that there are leads for the rear glass itself behind the headliner.
The only thing I don't have is the glass...have yet to find a 90-92 defrost glass at a boneyard that wasn't covered in nasty purple tint.
I always found it strange that nearly every 91-92 has rear defrost except mine...and mine's got just about every other option except WS6.
Old Oct 25, 2010 | 03:55 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I hope mine has the wiring as I have another hatch that I can put on with the defrost. Not used here much but is a blessing when it is needed. I will look for the relay when I strip a friends Camaro that also has it.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
E Rod
Aug 28, 2015 05:17 AM
