1991 ground effects question
Old Nov 6, 2010 | 12:26 PM
Toqwik's Avatar
I have a 1991 RS camaro. For some reason, the ground effect piece that goes on the bottom of the door has warped and is wavy. What years wil interchange with this piece. Looking around the yards, they all look the same to me. Anyone know?
Old Nov 6, 2010 | 01:22 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: 1991 ground effects question
I wanna say that any ground effects piece will FIT. It won't look right though. Obviously any ground effects piece from 91-92 will fit.
Old Nov 6, 2010 | 01:31 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
only the 91-92 door piece will fit...
Old Nov 6, 2010 | 04:33 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Yup, 91-92 are the only direct ones to match. You can actually take your door piece off and fix the "wave" you see - Its usually that the plastic has come off of the metal track on the mounting part.
Old Oct 10, 2012 | 11:24 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I have had two 91s, BOTH have had the GFX on the bottom of the DRIVERS DOOR that were warped. On the first one, when I pulled it off, the bolts were JUST off enough to not go through the holes in the door exactly, hence the warping. I have not taken it off on my new one, but I am guessing it is a similar problem?
Anyone else experienced this issue?
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
92firebirdchris
Aug 14, 2015 11:56 AM
