Welding rear hatch????
Car: 90 RS
Engine: 3.1
Transmission: ???
Axle/Gears: ???
I am thinking about welding the rear hatch so it is like a normal hatch and not a POS. I already have the motor and the slide and lock mechanism off. I think i am going to latch the inside part to the hatch and shut it and have someone push down a little on the hatch then i am going to tack it to the rails that mount to the car. If it works then i will weld it up solid. Any suggestions or ideals? Anything will help. Thanks!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Welding rear hatch????
why? thats a terrible idea, seriously.
you cant weld to the sides of the hatch glass, the trim is too thin and you will probably shatter the glass. So you are just welding the decklid? again why? it serves no purpose and you will loose access ot the back of the car for the spare tire and storage.
If you are trying to simply eliminate the electric hatch pulldown motor setup, you can pickup a manual one instead. Or if you really have to, use pins, similar to hood pins to hole the deck closed.
Just leave it alone.
***edit***
***edit***
Or you simply weld the slider part of the motor tight. Some fool did that to mine, I removed it and bought a NOS unit to get it working again.
Car: 90 RS
Engine: 3.1
Transmission: ???
Axle/Gears: ???
NO NO NO! I guess i didn't explain it will enough! MY BAD! The hatch pull down motor assembly. Where it slides up and down as it opens and closes. Usually there are nylon guides in there but mine turned to dust when i touched them. My gears are bad too. I would fix it but would rather weld it up to where it opens and closes like a normal trunk or hatch should. No motor and up and down crap to worry about breaking later.
Car: '88 Trans Am GTA
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
i did that as a quick fix to one of my cheaper 3rdgens. and it actualy works very very well. i had my girlfriend sit on the deck lid, and i was stuffed in the hatch with my welder propped in there and welded her solid.
i wouldnt do that to my nicer 3rdgens of course lol. i only payd $300 for this one, and the rear hatch was just hangin open and annoyin the **** outta me
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
welded mine. its flush on the sides but if i have the rubber bumpers on the corners in at all i can't get the latch to catch so i left them off. now when i drive the hatch wiggles and rattles. but it's alot easier than the pulldown being broken and having to manually wind it down before closing the hatch which was my problem. my plasic guides broke last time i took it apart too. i wish the parts were cheaper or i'd fix it.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Or you could just get the manual assembly from an earlier non-pulldown motor car and call it a day.
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Engine: 383 hsr
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
I drilled holes through the mechanism into slide rails and just bolted it in place.. That way if i decide to fix the motor i can just undo the bolts and go. Simple enough..
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Before anyone tries this it won't work. The mount for the latch is different and even the striker on the hatch is different. It was on my 88 anyway, 84 manual latch wouldn't work. Maybe if you change the brace in the rear body panel and the striker.
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
.Look here for hatch pull down parts. http://www.top-downsolutions.com/index.php?cPath=22 Joined: Sep 2007
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
They're not THAT expensive... no wonder us third gen owners get labeled as cheapskates. We will gladly buy fancy wheels and expensive hoods, but won't spend a little money to fix the hatch motor.
V6F1R3BRD's holes and bolts method is not a bad alternative though.
Car: 90 RS
Engine: 3.1
Transmission: ???
Axle/Gears: ???
Does anyone have pictures of how they bolted theirs down??? I am having a hard time visualizing that one and how to make it sturdy?????
Street Lethal
Apr 30, 2019 12:14 PM
