OE 4th gen TA spoiler
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Anyone done this? I have seen someone mention using a original 5th gen TA spoiler on a 3rd gen, but how does it fit if it has been done and what mods have to be done to make it work?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 87 GTA
Re: OE 4th gen TA spoiler
You didn't see mine at the Texas State Gathering? I think I saw your car there, maybe not.
Anyways....If you do it? Get a 93-97 wing. Despite the 98-02 wings LOOKING the same? They aren't. The bottoms are different. The "LS1" wings don't sit flat.
Here is my GTA with the LS1 wing & FYRCHKNs red TA with the LT1 wing.
Our wings....
EDIT:My bad....Thought it said 4th gen, since there is no 5th gen TA.
EDIT 2:Title says 4th gen so....."5th gen" was a typo in the post?
Our wings....
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I did not make ti to the state gathering unfortunatly.
But, how does it bolt on? Easy? Little to no modification? The LT1 piece looks like the way to go and a ton cheaper than the hawks piece i am sure, LOL.
Car: 87 GTA
With both the LT & LS wing, you have to drill new holes & plug the old ones (i welded mine shut) but the LT sits flat where the LS doesn't. My close up pics show how the LS bottoms sit at an angle/sloped.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I understand that, but what about where the wing wraps around the window? How do you secure that to the car?
Car: 87 GTA
Honestly, you don't need to.
Mine never have been fastened, nor have I ever had them move. I seriously doubt that you will find ANYBODY that has used a 4th OEM with with wing tips held down.
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Mine's been on the car for 3+ years now with no issues. There is no need to attach the wrap around arms. The wing is SOLID and once it's bolted to the hatch it aint goin anywhere.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Awesome, so basically, why the hell use a Hawks piece then. I hope to find one soon and surprise the wife on here 86 TA. Has no had a rear spoiler since 02.
Engine: LT-1
The one that Hawk's sells is a smaller made for our cars version that is bolt on ready. The OEM piece must be modified to fit. It requires taking some material off in some places and adding more in others. It's really not that hard to do.
Car: 87 GTA
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
That is where you have to ad to the LT1 wing or the LS1 piece?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Ok, apparently, the part numbers for the LT1 and LS1 are the same, so i need to mod one and get it on, because the LT1 piece is the identical piece. So, how the hell did one fit easier than the other in the above post Stephen?
AkDrifted
Aug 17, 2015 07:45 PM
