Lexan T-tops
Old Jan 10, 2011 | 09:29 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Lexan T-tops
I know there have been a few posts about interchangeability with glass. What I want to know is: Are the glass tops quieter in terms of rattling and squeaking. My lexan ones are noisy in that way and I was wondering if glass ones were quieter. I did a search and dint find anything.
Kevin
Old Jan 10, 2011 | 09:47 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Lexan T-tops
I've driven cars with both, including my own Camaro and there isn't a difference. If the tops are making noise, its because they are moving and the weatherstripping is not doing its job of maintaining a good seal. That, or the latch mechanism is worn and allowing them to vibrate. Neither problem is going to be dependent upon which type of tops you are using, nor will switching from one type to the other fix it.
Old Jan 10, 2011 | 11:29 AM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Lexan T-tops
I am sure I will need all new weatherstripping and adjustment. I am not expecting miracles but hopefully it will help.
Kevin
Old Jan 10, 2011 | 12:08 PM
Drew's Avatar
Re: Lexan T-tops
In my experience, the rubber squeaks when it moves against the plastic tops. Other then that, the plastic tops seem to seal better to the weatherstripping, they're lighter, they're tinted darker, and they don't rattle as much. If they didn't degrade so bad when exposed to UV, it'd be a slam dunk victory for plastic t-tops.
The tops are always going to be moving independent of the weatherstripping, it's nature of the beast with a unibody car with 3/4 of the roof removed. Subframe connectors to stiffen the body and silicone grease applied to the rubber so it doesn't stick to the plastic will eliminate most of the noise.
Old Jan 10, 2011 | 06:16 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Lexan T-tops
I eventually plan to do both. Thank you.
Old Jan 11, 2011 | 01:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Lexan T-tops
Have you tried adjusting them? If you remove the A-pillar and B-pillar plastics, you'll see where the 'holes' for the pins on the body of the car can be adjusted - loosen the bolts and they twist a tad to change the position.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
