Painting question
Old Jan 19, 2011 | 09:22 AM
davemel3nzc's Avatar
Painting question
Has anyone ever heard of mixing a little base coat in the clear coat before spraying the final coat?
I am getting my sons car painted by a friend, and that is what he wants to do. I have searched the threads here, and have not found any mention of this in all of the paint posts.
Thanks Dave
Old Jan 19, 2011 | 09:32 AM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
Re: Painting question
No, What would be the purpose ?
Old Jan 19, 2011 | 09:33 AM
He says it will give it a wetter deeper look.
Old Jan 19, 2011 | 09:43 AM
trocustoms's Avatar
I would be concerned if it is a metallic, it may model the metallics. I personally have never had to add base to clear to achieve a "deep wet look" Have him paint a test panel.One with and one without. See if you can pick which one is which.
Old Jan 19, 2011 | 02:19 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Neither have I. You can do it, but I doubt you'd be able to tell the difference. Test panel is a good idea.
Old Jan 19, 2011 | 02:53 PM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Never heard of that. If you want a deeper look, then careful wet sanding and buffing will achieve that. Tricoat painting is really the best way to get that deep effect.
Old Jan 19, 2011 | 03:18 PM
da.slyboy's Avatar
Car: 84 frankenstein Z28
The person who painted my truck did such a method. First coat base, second and third base with some clear, last coat clear. The paint was a fine metallic red. Looked good when it was all done. Does seem to give it a little depth.
Old Jan 19, 2011 | 04:55 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
It gives it a 3D kind of effect. Hard for me to explain. Imagine looking through your color and being able to see down to the bottom.
I like to do as mentioned, do your clear coat, sand and clear once again. If you can keep it clean and not run it (it will run easier) then there should be no reason, if done right, to sand and/or hit with a polisher. It will flow out real nice and looks much nicer that color sand and buffing.
Old Jan 19, 2011 | 05:08 PM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
never hear of it unless is pearls on the clear been painting for 5 years ppg certified
Old Jan 19, 2011 | 05:12 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Started doing Auto Body, frame and paint back in 1985 and have been told I am certifiable.
This is one of the tricks that the paint manufacters don't tell you.
Old Jan 19, 2011 | 05:19 PM
1BADZ28SD's Avatar
dont see the point of doing that if the already sell it mix already candys metallics its just a wasted of time, and year today is 2011
Old Jan 19, 2011 | 06:00 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Candies don't give the same effect. If you can look into the past and not be stuck in 2011, before all the pearls of today there were limits to what you could get. Most common was the paste you would see in red, blue, gold, etc.. It only took a small ammount on the tip of the stir stick to be enough for a gallon or so of clear. The effect it gave was a pearl floating in the clear that you could look through down to the color.
Mixing the paint that you used for the base with the clear keeps it the same color and gives it a layered effect.
Old Jan 19, 2011 | 06:50 PM
1BADZ28SD's Avatar
i know wat ur talking about like u said yourself before all the pearls of today in the past they where limits rite? on today's paint there are no limits ,u can do almost anything u can imagine returning into 2011 there's no need of doing that unless ur using crapy products i didn't know having a candy or metallic paint cost the same as a regular base coat color enough said
Old Jan 19, 2011 | 10:30 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
You are correct in one point. That being, enough said.
1985 was not the only year I have been doing this type of thing. I still paint today and use todays products. That makes over 25 years of experience.
I can see though that you will never get it. You're challenged enough with capitalization, punctuation and proper spelling. Stick to painting because they give you pictures for the mixing ratios.
Old Jan 19, 2011 | 10:38 PM
1BADZ28SD's Avatar
well sorry sir ... went u go a get a job who gets the job first a person with certification or a person that has " been told I am certifiable" does not matter how many years u have doing something if ur start doing it wrong for the past 25 years .... keep doing what u doing u must have a lot of customers who want paint mix in there clear that's gives u the 3D effect haha never hear of test panels ...
Old Jan 19, 2011 | 10:45 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I'll get the job. First thing they will see is that I can fill out an application! Second, I would not have lasted 25 years if I had been doing it wrong.
LMFAO!!!
I'm done with you
Old Jan 19, 2011 | 10:53 PM
1BADZ28SD's Avatar
i don't to fill out application lol i have plenty of jobs offer to me because i know what im doing well u have work because ur in ur garage paint like 25 years ago and probably the people that u do work for know less than u lmao ... done with ignorant fools ps we have spray boots now haha ... done and outs
Old Jan 19, 2011 | 11:06 PM
spr250's Avatar
Car: Divorce stole it
Engine: Divorce stole it
Transmission: Divorce stole it
Axle/Gears: Divorce stole it
It's nice how a question about paint turns into a P&*sing contest. Lets solve it now, just because someone is certified, it doesn't mean that they know what they are doing, it just means that they can pass a test. Having experience in something of X amount of time doesn't mean you know what your doing either, although I do recognize the fact that experience is a big factor for quality and being certified means usually the most up to date procedures. So instead of bickering like to high school girls over a boy how about you combine said skills and paint away.
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I have heard of this. They use this on musclecar, trucks, overhaulin. all those shows. I know painters that do great paints jobs and do this. Its a great thing to do.
Old Jan 19, 2011 | 11:10 PM
1BADZ28SD's Avatar
Old Jan 19, 2011 | 11:13 PM
spr250's Avatar
Ok seriously, dude, not to be mean-too much anyway, you really need to work on grammer and spelling. If I need a car painted, I would not have you do it no matter how well I think you do. Just a note, if your gonna verbally fight with someone, see above mention. Thank you and have a good night.
Old Jan 19, 2011 | 11:18 PM
1BADZ28SD's Avatar
done with this crap im not offering to paint for u so u know what whatever its a free country every body cant type and say whatever the want no more posting here
Old Jan 20, 2011 | 12:04 AM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
I heard of it, was under the impression it had something to do with candy. Heard it made it deeper blah blah.
In houston, "Wet" means 12+ coats of clear i believe lol...
Old Jan 20, 2011 | 07:36 AM
Hey, thanks for all of the useful information. Sounds like it can, and has been done. I was just a little worried since I had not ever heard of anyone doing it here on TGO.
Thanks for all of the replies, the information / knowledge that is shared on this site is priceless for those of us that don't work on cars daily.
Thanks again, Dave
Old Jan 20, 2011 | 08:55 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Never tinted the clear eh?
-- Joe
Old Jan 20, 2011 | 08:59 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thanks again, Dave
There is a million different ways to do something, and a million different results can be achieved.
Using the same materials, I've shot different test panels to get different effects out of a base to see what I liked the most, and I've experimented a bit. Most "certified" guys are trained to match OEM jobs for insurance work.
At the end of the day, if you don't like the way it looks sand it off and reshoot it.
-- Joe
Old Jan 20, 2011 | 09:06 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
-- Joe
Bravo.
Old Jan 20, 2011 | 05:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Doing what your not suppose to do is how to learn new tricks, some work and some don't.
Guy on another board wasn't going for the effect but his rat rod looked like it was covered in shiny brown leather in the pics.
But it wasn't, he just shot clear over the rust covered body.
And it has not only has lasted but looks great.
Other one I member on them biker build off, the guy burried carbon soot from a miss adjusted torch in clear and it was neat looking effect.
Ive even done goofy stuff myself, using the wrong thinner, hardner and paint together, all 3 didn't match, and when the shop teacher learned what I had done he freaked out like I had mixed up a bomb. Yet the results were nice and left him confused. [in school most stuff was donated or left overs, so it was like a grab bag of stuff]
Thinking outside the box / bowtie
Old Jan 20, 2011 | 08:31 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Staying on subject(some people seem to text too much, hence the grammar issues and I think he meant 'spray booths', not 'spray boots', but whatever...) base is the color and should only be laid down in sufficient enough amount to a)cover the primer/sealer and b) impart the necessary color. The clear coat is what gives the paint its 'gloss' and shine. I would think that adding color to it would just diminish the effect of both steps. Color sanding and polishing will bring out the 'depth' and wet look- you want that clear to be 'clear' unless you are doing something like tinting a taillight lens where it would be an appropriate thing to do, given you are not laying down color first. But this is all just my 2 cents...
Old Jan 20, 2011 | 08:53 PM
1BADZ28SD's Avatar
i was not going to post here no more but !!bravo!! .
Old Jan 20, 2011 | 08:55 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Old Jan 21, 2011 | 07:10 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
You can get away with tinting the clear with base, but the transparency of the base (i.e. toners) has alot to do with the overall effect. Painting "by the book" is great for collision centers and guys replacing panels on late model cars, but really cool effects can be gained by trying things that aren't supposed to work. Pick up a quart of HOK, Xotic, or from anyone one of the specialty lines from the big guys and give it a go.
To the OP, if you want deeper/wetter, don't tint the clear(there might be some delamination issues in the future depending on brand/technique), instead do the base and clear by the book, wait 3 days, wet 600 the car and clear it again with an over-reduced clear. The result should be wet and flat.
Old Jan 21, 2011 | 09:53 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I have been painting cars for 25 years and I have never seen anybody put base in clear I have seen people put clear in the final coat of a enamel paint job Im with micktroup2 I would think it would do the opposite since it has a basemaker
Old Jan 21, 2011 | 09:55 PM
1BADZ28SD's Avatar
where u hiding the past days? bravos.. lol
Old Jan 21, 2011 | 10:18 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Probably gonna' get hammered for this......
But my increasing problem with TGO is that by the time the "pissing matches" are over, the question originally asked is never answered.
So, can we all be a little more constructive? It would really help me with my projects.
Old Jan 21, 2011 | 10:50 PM
Engine: LQ4 ls 6.0
I would agree I had a guy working for me that went to WyoTech
and the guys at Alsa told them that they were developing a clear and ended up with a finish like leather and thats all cool but when I am painting car I am going with what I know works if you have to respray a car for free thats a bummer here is a link to that paint that look like leather http://alsacorp.com/products/softtouch/softtouch.htm
Old Jan 22, 2011 | 12:36 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Where have you people been?
When I first started doing this, the shop I worked at had a Ditzler mixing system. One trick that everyone knows (well mostly everyone) was to put paint in the clear when doing a clear coat so not to wait the long time that was set for enamals.
Places like miricale, maaco, earl, add the color to the clear all the time. That is what they call their "intergrated clear coat".
BTW,
I answered the original question. Its not my fault others are oblivious to it and never seen it.
Old Jan 22, 2011 | 12:38 AM
1BADZ28SD's Avatar
yup... low budge places....
Old Jan 22, 2011 | 12:49 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
They are not low budget any more.
I stopped at a shop I worked at for over 12 years (I finally had to just quit because I went and opened my own). The guy was doing some mechanical fon an old Oldsmobile for a frined. He told me that the guy had the whole car painted, no body work, at a miricale. Asked me the guess how much. I recall them doing those scratch and shoots for like $299 or so. I guessed $350.... He said they socked the old man for $1500!
Those places need to bring in a certain amount or the corp shuts them down. This is the last miricale in this area. I think with the economy they are socking who ever comes in.
Old Jan 22, 2011 | 12:58 AM
1BADZ28SD's Avatar
yes, experimenting is cool ... gets new ideas and blah blah but in today's economy is very hard to do ur own thing. i do jobs for around 4000 to 5000dlls since there are candys house of kolor paints i got no room for error or i get my a$$ handed to me . if u paint like that is cool , like 60% of the time guys are looking for cheap stuff .ppg prices go up every 6 months like 10% or so . my dad used to paint along time ago u could paint a car for around 600dlls with body work today u can even paint a fender, didn't mean to start a fight we just do our stuff different
Old Jan 22, 2011 | 01:01 AM
1BADZ28SD's Avatar
after all this a forum to help each other out not to trash talk ourselves
Old Jan 22, 2011 | 06:18 AM
  #42
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I can see where mixing base with your clear would give a candy effect but have you put clear hardner in reduced base coat before? Most base coats will harden or gel up in the gun. So if you put base in clear with hardner you're asking for problems IMO.
Old Jan 22, 2011 | 06:58 AM
  #43
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
One difference you have to understand is, for starters, you are in the liberal commie capital in the world when it comes to EPA regulations, so between the special paint, special booth, special gun, etc your costs are very high.
In this part of the country, there is a MILLION body shops shooting whatever they want, on whatever they want. Sure, the EPA may have some federal rules but the last time one of those guys poked his nose around these parts they never found the body.
I'm paying about $80 a gallon for base right now, so really, I can afford to experiment and screw up a million times.
A friend of mine just switched to the water based PPG and I know his costs are through the roof. He's losing a lot of business because most people will bring a car to a small shop that can shoot the car for $2000 using a cheaper high voc 2-stage paint, vs $4000-5000, especially when it's a $1500 camaro/mustang/etc.
I know the gallon of hawthorne I have in my garage right now will probably kill you when sprayed but it's cheap and it looks great!
-- Joe
Old Jan 22, 2011 | 07:01 AM
  #44
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've seen it done, though, i've never seen someone put the same color base in the clear.
The last time I saw it done, I think the car was shot in red, and they added like two capfulls of green to the clear.
-- Joe
Old Jan 22, 2011 | 08:16 AM
  #45
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
-- Joe
I know the pain of costs in the shop. Due to some bad info given from someone in the office, a 18 year old had her 92 Maro towed to the shop for paint. It had been repainted sometime under the delam recall. Dupont sticker in console. Clear was peeling everywhere (not bashing Dupont, all of them had problems then and it's at least 15 years old). Doing estimate with Pathways with new AM weatherstrips was over 5 grand. She was expecting 2. At 42 an hour there was no way we could paint that car there for that price. We're not using water based it's just the way dealerships are, we are anyway.
That's cheap for base. I bought a gallon, or two quarts of silver and two of purple, for 110 in Omni. Used Omni 282 clear that had been on shelf for 5 years and it worked good! I'm not even buffing that one. Very little trash even with my 20 inch box fan vent system at home. LOL
Old Jan 22, 2011 | 11:08 AM
  #46
1BADZ28SD's Avatar
-- Joe
rite on the dot joe . i have a gallon of ppg vibrance candy red for sale if any if interested lol
Old Jan 22, 2011 | 11:18 AM
  #47
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
-- Joe
And why Im still using $30-$40 a gal paint.
Looked good enough on 50-70s hotrods to get in mags, good enough for me
http://www.paintforcars.com/
Auto Paint starting at just $35 a gallon!
You'll find Car Paint such as Acrylic Enamels, Acrylic Lacquers, Clear Coat Automotive Paint and Urethane and Acrylic Primers.
Most recent paint job on my wagon, I got it from Menards, black Rustolum industrial enamel. All the threads on the net where folks have rolled or brush a car and it came out nice had me consider, well if I spray it right, it has to look even better. Damed if it didn't. Less then $100 to paint a land yacht.
Old Jan 22, 2011 | 04:09 PM
  #48
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
It is very possible that the person painting the car, who brought it up to the OP, has done it before and knows what they are doing and what paint to use.
Old Jan 22, 2011 | 07:51 PM
  #49
Engine: LQ4 ls 6.0
-- Joe
I think that would look cool I know PPG has a candy apply red that has base in the clear but it is a intercoat clear that is a clear base not the same as say 2021 clear
Old Jan 22, 2011 | 07:59 PM
  #50
1BADZ28SD's Avatar
thats what im selling lol its the orange base the candy red and then the clear 2021
