Help! window replacement
Old Feb 9, 2011 | 04:59 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
how do you replace the window i took everything out of the door minus the regulator i just can not get the dam thing in the door it has the mounting bracket attached to the glass
Old Feb 9, 2011 | 08:49 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Help! window replacement
Easiest way ive found, is thru the front(w/the tri seal removed).Thats the widest slot for the window to fit with the track still attached.
I forgot the exact sequence, but basically it goes in at an angle.Once the window is in, slide the track onto the nearest roller, lower the reg part way or so, slide window farther in & the track onto the second roller.
Old Feb 10, 2011 | 12:51 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
It is a REAL pain! but 84 1LE is correct. Just be patient...
Old Feb 10, 2011 | 10:32 AM
Red 87 GTA's Avatar
i drilled out the rivits that held the window in the braket and droped it in with the old bushings and small bolts
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
stalkier
Aug 21, 2015 01:54 AM
Wylecoyote08
Aug 14, 2015 08:28 AM
