blocking out after primer, how do I fill low spots?
Old Mar 20, 2011 | 03:55 PM
Part Timer's Avatar
I am startign on my front fender and after completing some body work. I hit it with some self etching primer then put on some guide coat to block it out. Now I have some low spots and a couple high spots showing up. What do I have to do to the low spots to get filler to stick? I put some filler in but when I hit it with sand paper it fell out. What do I need to to do for prep to the low spots to get them filled in?
Thanks for your help.
Bob
Old Mar 23, 2011 | 10:21 AM
sgtmac's Avatar
Car: 87 Fomula, bought new, October 86
Engine: 305 Quadrajet,
Axle/Gears: 9bolt now in, starting on body work
Re: blocking out after primer, how do I fill low spots?
Just a thought-seeing high and low spots after the first epoxy coat doesn't sound unusual. It means that everything isn't perfect. You may want to massage the low spots from the back side with just your hand and check for straightness with your largest sanding block while wiping water across it(if fixed, the low spot will be gone, if not, there will still be a wet spot where it is low).
Also, you are probably going to be putting on about three coats of high fill primer which will help smooth out the high and low spots, with progressive sanding in between each coat. The latest Muscle Car Review has an in depth article on painting a Chevelle where they used epoxy primer as a first coat and then as a sealer after the high fill primer. While filler may be necessary, you probably will want to get the metal as close as possible to have a great paint job!
Old Mar 23, 2011 | 11:13 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Filler needs clean metal to stick to- a glazing putty works on primer. I would lay down some more coats of primer and then block again. A high fill primer should be thick enough to fill in small depressions...
Old Mar 23, 2011 | 08:26 PM
Part Timer's Avatar
Thanks for the help, I really appreciate it.
Old Mar 23, 2011 | 08:43 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
You might try some evercoat polyflex 411 to fill small depressions. I hear it doesnt need bare metal
Old Mar 23, 2011 | 11:54 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Thats what I would suggest. I've used that stuff with good results for years.
Old Mar 24, 2011 | 08:09 AM
Opher's Avatar
Car: 92 Jamacia Yellow Formula 350
You can not put body filler over self etching primer. If you used an epoxy primer you could. IMO self etching primer is for quick in and out repairs.
Either way Self etching primer and epoxy arent really"blocking" primers. If you have a lot of bodywork done, apply 2-3 coats of a polyester type primer, its like liquid body filler.
backtothe80s
Sep 5, 2015 12:39 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
BurlyChev
Aug 16, 2015 09:08 PM
jackhammer
Aug 15, 2015 10:04 PM
