Mint condition bumper, but the wrong color
Old Apr 19, 2011 | 06:22 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Question for you. I just found a beautiful bumper cover for my camaro. there's not a chip of spider line crack on it. The only problem with it is the fact that it's bright RED, and my car needs to be grey.
When there aren't any issues with chips or cracks, what's the best way to prepare a part like this before recoat? Do I take it down to Base, factory primer, or just scuff up the clear and spray right over it? I know that the thicker the layers of paint on a bumper, the more likely spider cracks are later
Old Apr 19, 2011 | 06:39 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Mint condition bumper, but the wrong color
Clean it up, degrease it, scuff it, and shoot it with quality automotive paint. Sounds straightforward.
Old Apr 19, 2011 | 06:42 PM
58mark's Avatar
thanks, I was worried about putting Base and clear over base and clear. No issues with that?
Old Apr 19, 2011 | 06:56 PM
CruzinQueen's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
As long as it's cured you should not have any problem (and I am assuming it is perhaps the original paint?). Anyways, just scuff it with 400 grit wet to knock down what clear coat and any chips are in the existing paint to get a nice smooth surface to paint the new color and clear coats on. Be sure and degrease and use a flex additive in the paints if you can.
Old Apr 19, 2011 | 06:57 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Without seeing it, one never knows. Based on what you described I would say it isn't a problem. Always nice to put a light coat of catalyzed primer over it.
Old Apr 19, 2011 | 06:59 PM
58mark's Avatar
i guess when it's in my posession I need to test and area to see how thick the paint is on it. As nice as it looks, I doubt it's the original paint. I may find it already has base/clear/base/clear on it
This thing is beautiful.. too bad I don't have a red car
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LT1Formula
Aug 20, 2015 09:36 PM
LittleFranks
Aug 20, 2015 03:55 PM
AkDrifted
Aug 17, 2015 07:45 PM
Vintageracer
Aug 11, 2015 08:13 PM
