what makes upper door hinges special
Old May 7, 2011 | 12:18 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
These things are pretty expensive for what they are WHY? Is what makes them special just that they clamp the hinges together like a nut and bolt.
Old May 7, 2011 | 01:15 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: what makes upper door hinges special
it is designed to tie the door reinforcement into the car so it becomes one strong piece when the door is closed it also wears out so they no the get people to buy it
Old May 8, 2011 | 05:03 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
For those of you with greaseable hinges how does the grease work. Is it just a hole down the middle of the bolt and then a hole that passes through and let's the grease exit inside the bushing.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
