argghh t-top weatherstrip issues (new)
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
hey guys i just isntalled a NOS t-top bar and new weatherstripping (metro from 1aauto) and my issue is i cannot get the t tops back on the car they wont go far enough into the t bar to allow them to latch (ie cant push them toward the center of the car far enough)this the case on both sides i have re installed sealsjust to be sure they ARE installed correctly... any one have any expierence with this ..... thanks any help is appreciated
Car: 1987 Trans Am
Engine: LQ9/L92
Re: argghh t-top weatherstrip issues (new)
while the seals may be a bit thicker than what came off (the originals get compressed over time), they still should fit in. its definitely a tight fit the first time around. you can try wiping a little silicone spray on the seal when you try to put the top in for the first time to let it slide in a bit easier. if you used a lot of adhesive underneath (or didn't scrape all the old stuff off), it may have pushed the seal up a bit too
Car: 1984 Z28
i think in reality i might have used too much adhesive on the t-bar and its now too tight to the roof and makes the t tops too tight on the seal .... so off comes the tbar....AARGHH .... oh well hope it works ahhahhh
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I had same problem with mine! I put some wd40 on the edge(T-Top) and push them in at an angle, holding the outside edge up and moving it up and down while pushing in. It took a while but they went in. They were a pain but after a while its OK now.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
