Core support on my 83
Old Jul 19, 2011 | 01:56 PM
Toyojake's Avatar
Car: 83' Z28; 89' S-10; 04' Jeep
Engine: Z28: 87' 350
Axle/Gears: Stock 2.93's
So I'm currently fixing up an 83' z28 and the driver side corner of the rad core support looks as if it was crunched and " fixed " at some point. It still looks pretty bad. Small buckle in the corner. The outer hole behind the headlight is cracked and the whole corner is rusting. The bottom of the actual radiator location is actually bent upwards looks like someone used it as a jack point. And the flanges on the bumper brackets are bent too. It really isn't too bad and its all fixable as I have an 86 parts car with a straight front end. I want to know.. should I cut and swap the entire rad support or just the damaged pieces and replace them? Can upload pics if necessary.
Old Jul 19, 2011 | 05:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Core support on my 83
the "best" way would be to tear down the entire nose, replace the entire support and fix whatever else is damaged. Its a lot of work, and a lot of spot welds, but it owuld be the best fix.
Old Jul 21, 2011 | 12:00 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
The proper way is to put it on a frame rack and pull it back into tolerance before you begin the repair.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
