please help with my hatch!
Old Aug 22, 2011 | 09:50 AM
MrGoodroach's Avatar
I have an 86 sport camaro. I am in the process of doing all the bod work before I complete my v6 to v8 conversion. My problem is, all of the grommetts that go with my hatch hinge bolts through the glass are all corroded. I can't find them anywhere! I have everything I need to attach the hinges for the rear hatch to the body. The holes in the glass are larger than the bolts. The dealer can't help me because the part is discontinued. Search and search, but I can't find the part via internet either... someone please help me!
Mrgoodroach@gmail.com
Old Aug 22, 2011 | 12:14 PM
Dougs91's Avatar
Car: 91 Camaro
Axle/Gears: 3.23 limited slip from 91 Z28
Re: please help with my hatch!
I bought mine at Hawks third gen parts.
Old Aug 22, 2011 | 02:05 PM
I will look into that thank you!!!
Old Aug 22, 2011 | 02:41 PM
Well, that's solves my hinge "bolt" problem... THANK YOU! But what goes in the glass with that bolt? The hole is obviously to large for the bolt alone. Is there a grommet or some sort of filler that goes in with? What was in with the bolts I removed from my hatch was so corroded I can't even tell what it was! Lol
Old Aug 22, 2011 | 05:24 PM
My85IROC's Avatar
Car: 1985 IROC
Transmission: A4
Nothing, the larger hole is so you can adjust the hatch. good luck!
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
