Headlight conversion
Old Sep 29, 2011 | 10:40 AM
Bakers87IROC's Avatar
Car: 1989 Iroc-z Camaro
Engine: 5.7L 350
i have a 1987 iroc and am looking for 4x6 headlights tht are non sealed beam so i can convert to hid... where can i find good sets of non sealed beam 4x6 headlights
Old Oct 1, 2011 | 10:20 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Re: Headlight conversion
have you considered monte carlo or corsica headlight swap?
Old Oct 1, 2011 | 10:48 AM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
you would be better off doing a hid projector instead of just hid in a 4x6 headlight. you can get housings off of ebay cheap but you def dont want to put hid's in them.
instead buy them cut them up to put projectors in and off you go.
Old Oct 1, 2011 | 12:34 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
#1, your asking a headlight question in a TPI Engine section of the board. You should PM a Moderator & ask a Moderator to move your Post to the riught section.
#2, there are TONS of HID headlight threads (especially for the Camaros) already, including complete projector conversions. Just look in the right section or use the Search feature here on TGO & you'll easily find the threads.
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
