stripping paint?
Old Oct 16, 2011 | 11:43 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
stripping paint?
what do you guys do/use to strip a car down to bare metal? whats your process or what do you find works best or easiest?
Old Oct 17, 2011 | 08:52 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Re: stripping paint?
I used aircraft paint remover then washed the car and sanded with 600 grit to remove little pieces.
Old Oct 17, 2011 | 09:14 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
any specific brand of aircraft paint stripper? ive noticed things like that can be better than others on occasion
Old Oct 17, 2011 | 11:54 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
not sure i picked it up at one of the auto stores autozone/advanced it was in a white plastic bottle worked real good first 2 are of the rear quarter stripped and the last is finished and painted
Attached Thumbnails stripping paint?-1986-iroc-z-467   stripping paint?-1986-iroc-z-474   stripping paint?-1986-iroc-z-772
Old Oct 18, 2011 | 12:00 AM
gen3guy's Avatar
i have used this in the passed http://www.autobodytoolmart.com/klea...3-p-12815.aspx
Old Oct 18, 2011 | 08:56 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
and it just bubbles up and you scrape it off then?
Old Oct 18, 2011 | 06:31 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Sorry, I have not used stripper in years, we media blast now. Just remember you need a good rinse to nutrelize the stripper when you are done, then a good etching primmer, good luck
Old Oct 18, 2011 | 08:00 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
well would it even be necessary to strip it down to bare metal?
Old Oct 23, 2011 | 07:20 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
It may not need stripped if you are working with the factory finish. If it's been repainted then most likely I would strip it. I use an electric grinder/buffer with an 8" foam pad and 80 grit paper. Makes a dusty mess not a caustic one. And doesn't strip the parts you didn't want to strip but spilled some stripper on and ... you get the idea. It's also easier if you do run into a previous repair you can just not sand into it as much where if the stripper hits bondo it'll take it off too. Use nice new sharp disc's when doing flat panels like the hood so you don't warp it.
Old Oct 23, 2011 | 09:08 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
cars stripped completely, its half factory paint and the dumb po pray painted the other side
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
Amillionoh7
Sep 5, 2015 11:44 PM
